danandrita
Feb 16, 2020Aspirant
Some devices cannot connect via ethernet
Just got CenturyLink fiber internet service using their provided dsl/modem Zyxel C3000Z. Needed more functionality than it provides so I am trying to configure it with a Netgear R6700V3 (updated the...
- Feb 17, 2020
So I believe my problem to now be resolved.
I went into printer properties in control panel and found the IP addresses were incorrect.
I updated these to the IPs showing up in the Netgear connected devices screen and printers are now fully accessible,
meaning their admin tools can be accessed via IP in a browser and they can be printed to by device name from an application.
My other concern was the amber lights on the port LEDs. Confirmed that my printers both have 100mbps NICs so it stands to reason they will show up as amber (10/100 mbps) status versus white (1gbps) status. My previous Netgear router only displayed green or off, so the amber was new to me.
antinode
Feb 16, 2020Guru
> [...] I have two printers [...]
Not a very detailed description of either of them, nor of how they
were configured when they worked.
> [...] they were not accessible via either IP through a browser [...]
Any actual error messages? What were those IP addresses? And that
of the (unspecified) computer/device with the web browser?
> [...] or trying to send print to them. [...]
"send" from what? Did you remove your old printer definitions on
whatever that computer/device might be, and re-install the printers
there?
If you're talking Windows, I'd expect a network connection to a new
router to appear as a new Network Connection in Windows, which might
default to being a "Public" (instead of a "Private") connection, which
might affect access to a shared printer.
> [...] I can't figure out why the printers are not accessible through
> the ethernet connections.
I see no information here which offers any clues. By itself, "not
accessible" is not a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
- danandritaFeb 17, 2020Aspirant
- antinodeFeb 17, 2020Guru
> addresses were incorrect. [...]
Why didn't _I_ think to ask about those addresses? No, wait...If you have software which expects to find your (unspecified) "two
printers" at those (unspecified) "the IP addresses", then you might want
to look for "Specify the IP addresses that the router assigns" in the
User Manual for your router.> My other concern was the amber lights [...]
Also covered in the User Manual.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read.> [...] (updated the firmware to current) [...]
For future reference, as always, an actual version number would be
more useful than your opinion of what's "current", today.
