wayne2101's avatar
Nov 14, 2020
SONOS Can't be seen on wired network.
I have recently purchased a MK63 netgear system with an additional satellite. SONOS works with the Netgear system using the wifi, however I am unable to use my wired computer for SONOS. Connecting a...
  • plemans's avatar
    Nov 14, 2020
    So choose 1 method.
    Putting the netgear in AP (access point) mode tends to be the easiest.
    Here's the features it disables: https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
    You can still use its wireless and ethernet ports.
    You can start back at the beginning. Get your vigin media device running as you want it.  You don't have to use its wireless, you can disable wireless. Just leave the rest of its features running.
    Then follow the guide for putting the netgear in access point mode.
