Davidhere
Jan 11, 2018Aspirant
Sony LF-S50G Wireless Speaker
I have purchased a Sony LF-S50G Google Assistant wireless speaker. The problem is that the time is not displaying on the front of the unit, I took the first one back to the shop and they gave me a n...
- Feb 14, 2018
I found a solution to the problem....it was obviously something to do with the Google Home app on my Motorola phone.
I installed the app on my Sony tablet, connected to the Sony LF-S50G speaker....and there was the clock showing!
Jon75
Feb 14, 2018Initiate
Hi I've tried 3 different LF-S50G speakers and getting the same issue with each one. I don't think its a netgear issue as I have tried it with Netgear router and TP Link router at seperate locations.
Did you find a solution to your issue?
- DavidhereFeb 14, 2018Aspirant
- Jon75Feb 14, 2018Initiate
Thank you! Problem solved.
