basketballmap21
Jan 25, 2022Aspirant
Specific device not connecting to router while other are connected, works plugged into modem
My new work laptop is not connecting to wifi. It will say 'no internet, secured' or look connected, but not load anything. All of my other devices are still operating normal. I tried resetting the...
Jan 25, 2022Guru - Experienced User
Are you using a work vpn?
What modem/gateway is the router connected to?
basketballmap21
Not using VPN as I can't even get on the internet. It is connected to an Arris SB6190.
- plemansJan 25, 2022Guru - Experienced User
have you checked to see if it was blocked in access control?
