KippG
Feb 03, 2024Initiate
Specific sites not loading with R7450
I have a R7450 router that has been working fine. I have suddenly lost access via the router to a few addresses. This is what I get to these sites: This site can’t be reached
secure316.inmotionhosti...
- Feb 03, 2024
Have you enabled ipv6?
Are you using a different DNS provider or the ISP supplied ones?
Try a different DNS Server. Here's a few. Also remember to change the ipv6 dns server if ipv6 is enabled.
CloudFlare
IPv4: 1.1.1.1 and 1.0.0.1
IPv6: 2606:4700:4700:0:0:0:0:1111 and 2606:4700:4700:0:0:0:0:1001
GoogleDNS
IPv4: 8.8.8.8 and 8.8.4.4
IPv6: 2001:4860:4860:0:0:0:0:8888 and 2001:4860:4860:0:0:0:0:8844
Kitsap
Feb 03, 2024Master
Lack of access to a specific URL can usually be traced back to the DNS (Domain Name Server) you are using. Bypassing the router also bypasses the DNS settings in the router.
Are you using the DNS from your service provider or have you made changes?
Have you enabled IPv6 under advanced settings?
