Alexboiiii
Apr 12, 2021Aspirant
Spectrum 400 ultra internet only getting half speed
Hi, I just upgraded my internet service and can’t get more than 250 down from my router. I can if I connect into it, but other than that it’s only giving me half power. Spectrum came by today and p...
Apr 12, 2021Guru - Experienced User
what actual device are you testing on?
there's lots of misunderstanding about wifi and speeds. wifi speeds aren't the same as wired speeds. I'd recommend reading this article to understand more about wifi .
Alexboiiii
The gentleman who came to my house had a router that he plugged into my modem and got 450 wirelessly so the only component that changed was the nighthawk router. Sadly it seems like I will be having to get a new router. Cause the spectrum dude made it happen right in front of me so...
- plemansApr 12, 2021Guru - Experienced User
and was he testing over 5ghz/2.4ghz?
And what device was he testing on? Yours? or his?
You can always buy a new router but its usually not the router that's the limiting factor
- AlexboiiiiApr 12, 2021AspirantHe tested on 5ghz not sure what router but he was using my modem. My router is a r7000 dual band night hawk. He was using ookla Speedtest on his equipment and on his phone. We all connected to it and got the numbers over his router, so that’s why I know it’s the router.
- plemansApr 13, 2021Guru - Experienced User
You're not going to hit 450mbps on the r7000. Its a 8 year old device (released in 2013).
and comparing an 8 year old device to whatever router the tech brought isn't an apples to apples comparison.
