kbartley
Jul 23, 2018Aspirant
Spectrum Cable Modem and R7000 sudden issue
Spectrum recently upgraded my modem to the 400Mbs speed Told me need their router to "balance the signal". Obviously I don't think theirs is anywhere nearly as good. So I tried switching back to m...
- Jul 23, 2018
Definately power cycle the modem and router together.
You might need to factory reset the router and then walk thru the setup wizard while the router is connected to the modem. It should connect...
kbartley wrote:
Spectrum recently upgraded my modem to the 400Mbs speed Told me need their router to "balance the signal". Obviously I don't think theirs is anywhere nearly as good. So I tried switching back to my Nighthawk Router after they left. I get a red light on the internet indicator (second from the left) and one of the items plugged in to the back of the router throws a red light as well. Moved it to a different port on the back and still have a red light. So is my Nighthawk now junk?
Jul 23, 2018Guru - Experienced User
Is that the model# listed on the front or the sticker of the modem?
This modem have wireless and or a built in router by chance?
kbartley
it is on the sticker of the modem. It does not have wireless or a built in router
- myerswJul 23, 2018Master
OK. If jst a modem have you gone through the normal process. Power down both the modem and the router. Then power up the modem and let it stablize, about 2 minutes normally, then power up the router. Thing of note the router should be set as getting DHCP from the modem and the Ethernet cable from the modem should be plugged into the WAN port on the router. Should then get Internet connection hopefully.
