RIgus
Aug 25, 2021Follower
Spectrum modem upgrade to connect to RS400.
Community, I recently upgraded my home network to Spectrum's 1Gig Mbps service, up from the 400 Mbps service, connected to my RS400 Nighthawk Router. Is the RS400 sufficient for 1Gig Mbps network...
Aug 25, 2021Guru - Experienced User
The RS400 is capable of wired gigabit speeds. Its not going to hit gigabit wireless speeds but close to all AC routers won't either.
And even most AX routers won't hit gigabit unless you have a compatible wireless AX device and are close enough.
so will it hit work for your network? Sure.
Does it provide all the speed that your network needs? Thats up to you to determine
