mitchpman13
Jun 23, 2017Aspirant
Speed drops with Firmware V1.0.8.34_1.2.15
Hello, Just got an email about this update and went to install it on my router. Well, I'm currently running at 10% of my current net speed after installing the update. Is there a new firmware revisio...
- Jun 23, 2017
Have you factory reset the router and set up from scratch.
Disable QoS and IPv6, save settings and reboot.
Besure to do any speed testing with a wired LAN cable connected PC.
Jun 24, 2017Guru - Experienced User
Glad you got it working. Enjoy.
