blossomjulianne
May 23, 2020Aspirant
Speed is slower when connected to router R6400v2
My internet speed when connected to my ISP's modem is 95mbps, when connected to the router it is only 8mbps, sometimes less.
I removed gadgets around it (i.e. Netgear Arlo base), moved it up high near the ceiling, and away from all other electrical interferences,. It has increased to 17mbps but still far from my ISP's 100mbps plan. I have tried both wired and wireless.
blossomjulianne wrote:
My ISP's modem is HUAWEI EchoLife HG8145V
Not easy to find that, but it looks like it could be a "gateway", with a built-in router.
Does it have a bunch of LAN ports on the back? Does it also do its own wifi? That would confirm it.
If so, you are trying to add a router to a router.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router. Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR SupportRemember, your wifi will never be as fast as a wired connection. And the speed of the wifi devices is down to them rather than the router.
- Margare1tAspirant
It's worth turning it off, if only to test your Internet speeds afterward
What is this modem?
- blossomjulianneAspirant
