pete0369
Aug 25, 2020Aspirant
SPEED issues compared to when bypassed
I have Verizon internet and when I bypass my router, I am getting close to 400 Mbps speeds (using fast.com) Now, when I use my Nighthawk R6700x3 router, I am getting close to 100 Mbps (previously wa...
- Aug 25, 2020
Have you tried a factory reset? Sometimes it fixes speed issues
microchip8
Aug 25, 2020Master
pete0369
Yes, I have tried the factory reset, but then the internet stopped working altogether and I could not get it going again. Instead, I ended up restoring the settings (I had backed up) in order to get things working again.
- pete0369Aug 27, 2020Aspirant
UPDATE - I was able to finally get the factory reset to work with my modem and now I am getting full bandwidth speeds! RESOLVED! Thank you.
I'm not sure why it is so challenging after doing a factory reset to get the router to recognize the internet though. I had to mess with it for a good 20 minutes or so, trying my old DNS settings manually for a while and then eventually switching back to AUTO for all the basic settings until it finally saw the modem. Now getting about the same speed with router in place as without router in place (modem to PC direct).
