nelsonwcf
Mar 29, 2016Aspirant
Speed issues depending on which channel I connect - Possible hardware issue:
Hi, I purchased a R8000 about 1 month ago and it worked pretty well. Last week, I was reading a review on the router which suggested turning on the Smart Connect. That's when the issues started. ...
- Apr 19, 2016
Since I started the topic, let me give it a closure. My issue was that I had a USB Wireless Dongle from Panda which performed well in the Secondary Channel (High Channel) but ridiculously poor in the Primary Channel (Low Channel). Since I had Smart Connect turned on, I couldn't control which channel my computer connected and appeared the problem was with the router.
That said, I noticed a better balancing between devices when I disabled the dynamic QoS option. I don't know if the algorithm for the dynamic QoS is just bad or its implementation by the current firmware (V1.0.3.4_1.1.2) is bugged.
Anyway, right now everything is working fine at my home. Comcast Blast of 150Mbps and the speedy tests getting between 157 to 153Mbps in the tests using any of the 5G channels.
Rising_Star
Apr 02, 2016Aspirant
This interesting in that I came here looking for any solutions to a very similar problem with my R8500. I have not tried disabling smart connect, yet, but will give that a try when I return in one week. My issue has been that since upgrading to the Comcast 150Mbps tier, Business Class, my bandwidth seems to slowly degrade on the LAN side. A test from the router using the speed test in the dynamic QoS shows that Comcast is not degraded and I am at least getting the expected bandwidth to the router. Passing through the router I experience degradation over time. A reboot sets me back to the expected bandwidth but over a few hours I will experience degradation and even the appearance of no internet connection. Using the Speedtest website and testing against a nearby Comcast server as well using Comcast's own speed test site I see my bandwidth, over time, creep as low as 30Mbps. Interestingly, running the same test from a Galaxy Note 5 on the WiFi side obtains about 130Mbps and I have yet to see any degradation there. Other devices such as my Smart TV, my Roku, and various laptops on WiFi will lose internet; i.e. no internet access but still connected to the router. During these moments I have noticed that accessing the router via the web UI is also problematic---laggy or non-responsive. I should mention here that the my primary machine that experiences the slow degradation is wired to the router using CAT6 STP, 10ft.
It appears to me that this may be a thermal problem. I have noticed there were more problems today than others (had to reboot four or five times) and invariably the temperature in the home was considerably warmer. I will be on vacation for a week and will continue troubleshooting upon my return. My first thought is to put a little fan near the router to circulate the air better. Should that not resolve the issue, the I will swap out the router for my previous router, the R7000, to see if it experiences the same problem. If the R7000 doesn't experience the same problem then I will revert to the R8500 and begin an in-depth analysis of the problem.
It should be noted, too, my previous tier was at the 50Mbps speed. With this tier the performance was consistant and never dropped below 50Mbps. On the 150Mbps tier I have seen the performance drop to less than 50Mbps.
