BigOunce
May 14, 2021Aspirant
Speed limited on X6 AC3200
Hello everyone. I have a strange issue with my X6 Nighthawk. I have Virgin Media 600MBPS internet but I only ever get 210MBPS on 5Ghz channels even when next to the X6 router. I am currently using th...
May 14, 2021Guru - Experienced User
A lot of wireless speed is dependant on the device you're testing on.
a 1x1 client is going to half the speed of a 2x2 client. And even the R8000's average throughput was never that great being a triband. The tribands allow more devices to be spread out on the 2x 5ghz bands for a higher total throughput but not necessarily higher peak throughput.
- BigOunceMay 14, 2021AspirantI’m using an iPhone 12 Pro Max for the tests. So does that mean I’m going to have to buy a faster router ?
- plemansMay 14, 2021Guru - Experienced User
the R8000 is a solid triband AC router.
Like I said, the benefit to the triband is the 2x 5ghz bands so you can spread devices out and have more than 1 device using a lot of bandwidth.
What do you need more speed for? Most streaming devices only user around 25-40mbps for 4k. and gaming is even less than that.
You'll only really see a benefit if you're doing large file downloads.
- BigOunceMay 14, 2021AspirantThe other issue is it still is capped while using the Ethernet ports. I have it directly plugged into my PS5 but I only get 200Mbps over Ethernet
