Beekerboy
May 31, 2022Follower
Speed lss after firmware update 1.02.90
I had 200MBPS from provider until i updated firmware to 1.02.90. Now I get maybe half. It happened before and a reboot fixed the problem but this time it hasn't. Any Ideas??
1 Reply
What router do you have?
What modem/gateway is it connected to?
Anytime theres an issue after a firmware update, the first step we usually recommend is a factory reset/reinstall. did you try that?
