davidk1952
Mar 12, 2023Luminary
Speed test odd results
Just a question. I run both Okla and Spectrum speed tests on my notebook... when I am connected to my ethernet the speed is great push go... Bang I am seeing my speeds... Then, I remove the e...
michaelkenward
Mar 13, 2023Guru - Experienced User
davidk1952 wrote:
Michael, thanks for responding and I actually thought my equipment was listed (I'll fix that)
My router is a Netgear Nighthawk S4 2350 Dual Band. My laptop is a Dell I7 with the intel 9250 wifi card. I sit about 15' from the router. I have both a hardline Ethernet connection and Wifi and switch off from time to time. I do understand that the wifi will be slower than the ethernet, I get 500-580mpbs. My WIFI is as I said mostly runs at 300-400mps.
S4 2350 Dual Band is not a router that I can find in the Netgear system. These have model numbers like RXXXX, Orbi RBKXXX. And dual band could be anything.
If this is a 5 GHz connection, then 15 feet could be a stretch, depending on what's in the way. 5 GHz is faster but has shorter range.
The Nighthawk application is not compatible with my router so I use the Netgear genie from time to time.
If Nighthawk app won't work, then we are talking about an ageing router. Just about everything in the past five years has use the app as a way of setting up the router.
Is that the mobile genie or the desktop version?
genie | Product | Support | NETGEAR
I use that even though my routers do support the Nighthawk app.
Lately what I have seen is while running my wifi and running the speed test I find that the first few times I run the test my speed will spin up to around 300mbps and then you can watch the speed drop to anywhere from 120 - 160mbps... when I run the test 2 or 3 times it seems to lock in between 300 - 400mbps and holds steady.
Test of WiFi speed over the Internet are famously all over the place, and can depend on the network between you and wherever the test happens. There are just too many variables ro make a single test meaningful. When I want to do a scientific test, I run tests on a half a dozen different test sites. Then I plug them onto a spreadsheet.
Are you trying to sort out some sort of problem in your network, or simply interested in speed measurements? If speed is what matters. then don't use WiFi when it isn't essential. You seem to have that covered.
As to going up to Gb Internet, you may not get near that with your hardware.
Speeds of 300 to 400 Mbps seem pretty good with most WiFi. A faster Internet connection isn't likely to get you much faster than that.
davidk1952
Mar 13, 2023Luminary
Good Morning Michael, Thanks for your reply, Sorry about not being more specific on my router ... but Yes it is an older device, I think I purchased it in 2016 or 17 to the best of my knowledge... it is an Nighthawlk R7500 V1 and here it is on the Netgear site https://www.netgear.com/support/product/r7500 I am looking at a number of options to upgrade it but I am waiting to see what I do with my ISP. My current Spectrum account is a 500mbps cable and because of some promo's going on I am able to get the 1gb for $20.00 per month less... Yep, it's a nice saving and bump in speed. True with the current equipment I will be hampered some what but, I am not sure which way I want to go in my upgrade.
I also am waiting to see if United Communications will come through and install fiber they are new to our area and have some great promotions which will also drop my monthly cost by $30 for 3 years, believe it or not they are saying that they will start running the fiber soon but it looks like they will be behind the projected date. So either way by changing my connection I will save money through the promo... And again, Yes I do understand that with my current equipment I won't be getting the maximum speed so I am looking at my options I am just not sure which way I want to go but because I have everything set with cables already run I tend to lean twards a desktop like the RAX500 or similar...
15' does not seem to be a hamper, I can take the laptop to the router and my tests don't change and yes, I stay on the 5g AC band. But, you re right hard wire will always be the best if I need extra speed for anything I just plug in to my ethernet cable.
The genie app I use is on my phone, I've not really looked to see if they have a windows 10 version or not... Yes I understand the new app will not work with my hardware and for now that is fine.... If I need to make adjustments I log in to the router over ethernet.
I have been running speed test for years and have a pretty good history, I understand running speed test at different internet sites will bring different speeds and that isn't a problem, I've got a pretty good idea what I am looking for.... Your right even using Oakla and changing servers there can be a huge difference ..I typically run the same known servers that I've run for years and they have been pretty constant..
So, the main reason on my post was that I have noticed that using my wifi lately I using the windows 10 desktop app when I open the app (no other programs running) when I run the test the app will connect and the speed will move up to the 300 or so range then, it will slowly fall back to the 120 -150 range and stay there, I'll run the test again and the speeds again will go up to the 300 or so range and then fall back to say 200 to 250.... then I run it again and the speeds to up past the 300 to 375 range and hold... it is just weird and I am trying to decide is it my laptop or router that is causing it. Once I get up to speed it seems to stay there .... just weird... Its like a car, say you hit the gas, car speeds up to 90mph, then slowly falls back to 50mph like your running out of gas 🙂 It really isn't a problem because it works itself out.. I was just wondering if anyone else had seen this in testing.
As for equipotent, I am leaning towards a robust router as if to future proof the set up at least for a few years! I have considered a mesh system but with my set up Im not convinced it's worth going that way .
Hopefully that covers your questions and again thanks for the comments.
- michaelkenwardMar 13, 2023Guru - Experienced User
There is no Windows version of the mobile genie. The desktop program is completely different. Netgear wants to kill it, but I use it daily for various things.
.... I am leaning towards a robust router as if to future proof the set up at least for a few years! I have considered a mesh system but with my set up Im not convinced it's worth going that way .You are correct. A good router will be future proof. As to Mesh, only you know that, but Netgear is pushing it hard with the Orbi stuff and, perhaps more relevant for someone who doesn't need hand holding, the MK range.
But with new models, beware missing features. I still use an R7800, still recognised by some as Netgear's "work horse" router, because it has access to USB storage, a poor man's NAS. But Netgear is about to cripple that by shutting down ReadyCLOUD.
- davidk1952Mar 13, 2023Luminary
Morning again... What desktop app/program are you using, do you think its compatible with the R7500 ?
My guess is the Orbi is making a lot of money for Netgear, and for some people it may be a way to go... I'm old school, I like the desktop router and if I need expantion (which I do to my recording studio) I just put an AP off a Ethernet run from the main router.
I started to think about upgrading to and AX210 in my notebook... just to again future proof in the event I ever wanted 6e... then I noticed Wifi 6 is directed to Windows 11 (did I say I hate Microsoft) that is crazy... I did the compatibility test for 11 and our laptops (and probably most desktops) are not technically compatible to Windows 11. I have several recording applications and plug in's that cost thousands of dollars that are not Windows 11 compatible and I will stick with 10 for them.
I've read a lot of good things on some of the Asus routers and honestly, they give you a lot of bang for the buck as well as a 3 year hardware warranty and lifetime tech support... Netgear just Pisses me off with their 90 day support unless you spend more money... I'd like to stay with Netgear but the more and more I find out I may give Asus a try.
No doubt my next router will be Wifi 6 compatible and maybe even Wifi 6e even if I don't use it right now.... no use in buying an older Wifi 5 router at this point... Actually mine is running fine and I am use to it... I'd just think that the newer units have faster more powerful processors that may help over all. I think at any point I have about 40 devices connected... not all running or being used, they just are there... it's easy got get up there, I was told the the R7500 will max out at about 50 devices... I find it funny Netgear makes a point of device count where Asus never brings it up.
I hope to hear from Charter today about the 1gb upgrade (no hardware upgraded needed they just do it all from the central station) no wires to run . and my monthly bill will drop by $20.00 🙂
Thanks for the info and suggestions.... chasing technology can wear you out... the changes are so fast!
The one in the link in my earlier message.
There is no compatibility issue. In effect, the program is another way into the browser graphical user interface (GUI).
I like it because it has some easily accessed features, including a network map where is much easier to manage devices than the "Attached Devices" page in the GUI.
