davidk1952
Mar 12, 2023Luminary
Speed test odd results
Just a question. I run both Okla and Spectrum speed tests on my notebook... when I am connected to my ethernet the speed is great push go... Bang I am seeing my speeds... Then, I remove the e...
michaelkenward
Mar 13, 2023Guru - Experienced User
davidk1952 wrote:
The genie app I use is on my phone, I've not really looked to see if they have a windows 10 version or not...
There is no Windows version of the mobile genie. The desktop program is completely different. Netgear wants to kill it, but I use it daily for various things.
.... I am leaning towards a robust router as if to future proof the set up at least for a few years! I have considered a mesh system but with my set up Im not convinced it's worth going that way .
You are correct. A good router will be future proof. As to Mesh, only you know that, but Netgear is pushing it hard with the Orbi stuff and, perhaps more relevant for someone who doesn't need hand holding, the MK range.
But with new models, beware missing features. I still use an R7800, still recognised by some as Netgear's "work horse" router, because it has access to USB storage, a poor man's NAS. But Netgear is about to cripple that by shutting down ReadyCLOUD.
davidk1952
Mar 13, 2023Luminary
Morning again... What desktop app/program are you using, do you think its compatible with the R7500 ?
My guess is the Orbi is making a lot of money for Netgear, and for some people it may be a way to go... I'm old school, I like the desktop router and if I need expantion (which I do to my recording studio) I just put an AP off a Ethernet run from the main router.
I started to think about upgrading to and AX210 in my notebook... just to again future proof in the event I ever wanted 6e... then I noticed Wifi 6 is directed to Windows 11 (did I say I hate Microsoft) that is crazy... I did the compatibility test for 11 and our laptops (and probably most desktops) are not technically compatible to Windows 11. I have several recording applications and plug in's that cost thousands of dollars that are not Windows 11 compatible and I will stick with 10 for them.
I've read a lot of good things on some of the Asus routers and honestly, they give you a lot of bang for the buck as well as a 3 year hardware warranty and lifetime tech support... Netgear just Pisses me off with their 90 day support unless you spend more money... I'd like to stay with Netgear but the more and more I find out I may give Asus a try.
No doubt my next router will be Wifi 6 compatible and maybe even Wifi 6e even if I don't use it right now.... no use in buying an older Wifi 5 router at this point... Actually mine is running fine and I am use to it... I'd just think that the newer units have faster more powerful processors that may help over all. I think at any point I have about 40 devices connected... not all running or being used, they just are there... it's easy got get up there, I was told the the R7500 will max out at about 50 devices... I find it funny Netgear makes a point of device count where Asus never brings it up.
I hope to hear from Charter today about the 1gb upgrade (no hardware upgraded needed they just do it all from the central station) no wires to run . and my monthly bill will drop by $20.00 🙂
Thanks for the info and suggestions.... chasing technology can wear you out... the changes are so fast!
- michaelkenwardMar 13, 2023Guru - Experienced User
The one in the link in my earlier message.
genie | Product | Support | NETGEAR
There is no compatibility issue. In effect, the program is another way into the browser graphical user interface (GUI).
I like it because it has some easily accessed features, including a network map where is much easier to manage devices than the "Attached Devices" page in the GUI.
- davidk1952Mar 13, 2023Luminary
I am pretty sure that is what I get by going in to the router by using the URL and I do use that often
It is nothing like anything I have ever seen in the GUI for the various Netgear routers I have owned.
