davidk1952
Mar 12, 2023Luminary
Speed test odd results
Just a question. I run both Okla and Spectrum speed tests on my notebook... when I am connected to my ethernet the speed is great push go... Bang I am seeing my speeds... Then, I remove the e...
michaelkenward
Mar 13, 2023Guru - Experienced User
davidk1952 wrote:
Morning again... What desktop app/program are you using, do you think its compatible with the R7500 ?
The one in the link in my earlier message.
genie | Product | Support | NETGEAR
There is no compatibility issue. In effect, the program is another way into the browser graphical user interface (GUI).
I like it because it has some easily accessed features, including a network map where is much easier to manage devices than the "Attached Devices" page in the GUI.
davidk1952
Mar 13, 2023Luminary
I am pretty sure that is what I get by going in to the router by using the URL and I do use that often
- michaelkenwardMar 13, 2023Guru - Experienced User
It is nothing like anything I have ever seen in the GUI for the various Netgear routers I have owned.
