Hellraiser2167
Apr 13, 2021Aspirant
Speeds are slowed down when connected to router R8000
I get 520mbps with my modem hardwired connected to my laptop. When I connect to the router I drop down to 265mbps. Any one have suggestions as to what could be causing the router to knock down my spee...
Apr 13, 2021Guru - Experienced User
what modem is it?
What firmware are you on?
Have you tried disabling qos, access control, parental controls, and traffic monitoring? (then reboot the modem after disabled)
- Hellraiser2167Apr 14, 2021AspirantFirmware V1.0.4.68_10.1.75
Qos- Off
Parental-off
Modem
Frontier Arris NVG468MQ- plemansApr 14, 2021Guru - Experienced User
traffic monitoring and parental controls are off?
Even after disabling them, sometimes a factory reset is needed to re-enable ctf that allows for faster speeds.Also, your Arris NVG468MQ is a modem/router combo device
It can cause a double nat as well as it has its own qos/traffic monitoring.
