Hellraiser2167
Apr 13, 2021Aspirant
Speeds are slowed down when connected to router R8000
I get 520mbps with my modem hardwired connected to my laptop. When I connect to the router I drop down to 265mbps. Any one have suggestions as to what could be causing the router to knock down my spee...
Apr 14, 2021Guru - Experienced User
what modem is it?
What firmware are you on?
Have you tried disabling qos, access control, parental controls, and traffic monitoring? (then reboot the modem after disabled)
Hellraiser2167
Apr 15, 2021Aspirant
Firmware V1.0.4.68_10.1.75
Qos- Off
Parental-off
Modem
Frontier Arris NVG468MQ
Qos- Off
Parental-off
Modem
- plemansApr 15, 2021Guru - Experienced User
traffic monitoring and parental controls are off?
Even after disabling them, sometimes a factory reset is needed to re-enable ctf that allows for faster speeds.Also, your Arris NVG468MQ is a modem/router combo device
It can cause a double nat as well as it has its own qos/traffic monitoring.
