NG27
Aug 20, 2023Aspirant
Speeds capped at 100mbps, im supposed to have gigabit R7000 paired with CM1000
i have tried everything i can think of to resolve this issue with no luck. ISP has confirmed GB speeds on the line itself.
michaelkenward
Aug 20, 2023Guru - Experienced User
Not a lot to go on there.It is a bad idea to try to cram the whole issue into the subject. There isn't room for a proper explanation.
You can help people to help you by providing the information suggested in this forum's header:
Subject (Include model number and brief summary)
Model (Recommended - Helps the community give the best answers)
Body (Include additional detail including model version, firmware, OS and environment where relevant.)
They are there for a good reason.
NG27
copy, well as i stated, my ISP came out and verified speeds on the line, everything checked out on their end. When i turn my modem on, all lights are green as should be but when i turn router on and try to connect my PC via LAN it turns the LAN light on modem amber, which indicates 100mbps. I used to get roughly 850 down and 40 up. My down speed sits around 90 right now.
