PL8SWPR
Aug 28, 2021Aspirant
Speeds drops intermittently - Doesn't happen when router bypassed
I have had the router for a couple years. Warranty expired last week. No issues until today. Internet speeds drop from 80 to 2Mbps every few minutes. Anything I watch buffers routinely. I am usi...
PL8SWPR
Aug 29, 2021Aspirant
For the several years (last 2 years with this router) multiple streams (up to 5 or 6), no issues. All of the sudden, streams start buffering if 2 or 3 are going at once. Speed tests show a drop from normal to 2Mbps back to normal. I have a 75/75 connection from Verizon.
Verizon had us run speed tests when connected directly from their equipment (the ONT outside) to a computer. Since that test showed normal speed, they blamed the router. They also tried to say that 75Mbps was only good for 2 or 3 streams.
I have upgraded firmware and did a factory reset this morning. Still having issues. I am on the verge of just upgrading the router to the R8000P just to make sure it isn't the router. I have a hard time though believing that with no changes, the router all of the sudden stops handling our normal traffic.
michaelkenward
Aug 29, 2021Guru - Experienced User
Makes some sense for wifi.
All those "go fast" claims on the boxes are less impressive when you realise that they don't take account of the growing number of wifi clients that we throw at our routers.
You can hardly expect a 75 Mbps Internet link to suddenly allow three, or more, wifi devices to connect simultaneously to the Internet and deliver 75 Mbps, or faster, each.
- PL8SWPRAug 29, 2021Aspirant
I certainly do not expect 75Mbps on all devices. What I expect is to be able to stream video on 3-6 devices with that 75Mbps as I have been doing for severa l years with no issue.
I just upgraded the service to 200Mbps. We will see what happens - should be more than enough now for sure.
Question remains - is there something in the router that could have all of the sudden gone bad to cause buffering issues when running multiple streams (1 per connected device)? Would I just be wasting money if I upgraded the router?
- michaelkenwardAug 29, 2021Guru - Experienced User
Remember to reset the router when you sigh in to the new service. You need it to forget any settings that it inherited from the old connection.
Piling on connection after connection certainly means that the router has to work harder at detecting connections and managing traffic, even if they are not all busting a gut simultaneously. That is just one of the tasks that eats up processor power. Others include QoS, traffic metering and parental controls. Time spent on those tasks is time not spend handling traffic.
The R7000P is a reasonable capable router. (I own one.) But all of these things get overtaken. Then again, a message came up here earlier from someone running a router from 2009 that seemed to suit them just fine.
Appears it was the router. I picked up the AX5400 and everything is running solid now. The 200/200 connection is giving 300/335 with multiple streams running.
One pet peeve on the routers is the lack of a mounting template and mounting screws to use with the mounting holes in the back.
