JezZedex204
Mar 23, 2020Aspirant
Speedtest on Netgear Genie showing as 44kbps
I am somewhat confused about this and cannot find a definitive explanation. What I would like to find out is whether this is correct or if I have an issue or setup problem. I am not too clued up on t...
- Mar 23, 2020
Best way to manage your router is by using its Web GUI at http://192.168.1.1
All the other apps/programs by NG are cr@ppy
microchip8
Mar 23, 2020Master
Because Genie is cr@p? Stop using **bleep**ty apps
- JezZedex204Mar 23, 2020Aspirant
Thanks.
I don't use **bleep**ty apps! What are they? Hold on, don't answer because apparently I should stop using it.
I presume what you are saying is ignore the readings. Cheers, will do.
- microchip8Mar 23, 2020Master
Thank you, got there using 192.168.0.1
