JezZedex204's avatar
JezZedex204
Speedtest on Netgear Genie showing as 44kbps
I am somewhat confused about this and cannot find a definitive explanation. What I would like to find out is whether this is correct or if I have an issue or setup problem. I am not too clued up on t...
  • microchip8's avatar
    microchip8
    Mar 23, 2020
    Best way to manage your router is by using its Web GUI at http://192.168.1.1
    All the other apps/programs by NG are cr@ppy
