Munchoba
Sep 13, 2022Tutor
Sporadic loss of internet connection with R7000P
Hi, For a few months now, my router loses it's lan and wifi connection. I'm not sure where to start troubleshooting. Firmware is up to date. Any ideas? thanks
- Sep 13, 2022
Try putting your helix in router mode and the netgear in access point mode.
to often I see "bridge" mode not function properly.
Just make sure if you leave wifi enabled on the helix to have them on different channels to prevent interference.
Sep 13, 2022Guru - Experienced User
Details help.
- what actual firmware version are you on?
- what modem/gateway is it connected to?
- how frequently is it happening?
- does it happen to all devices? or specific to wireless devices?
- when it happens, does it say "connected, no internet" or what actually happens when you're having issues.
Munchoba
Sep 13, 2022Tutor
Hi,
Thanks for your help:
- what actual firmware version are you on? v1.3.2.134
- what modem/gateway is it connected to? Our local provider calls it Helix; I bridged it. From provider's site: Branded as “Helix,” the new tech includes the same wireless video set-top and DOCSIS 3.1 WiFi gateway used in the U.S. by Comcast X1 subscribers. According to Lightreading, Videotron is using gateway hardware manufactured by Technicolor using Broadcom chips.
- how frequently is it happening? once, twice a day.
- does it happen to all devices? or specific to wireless devices? All devices . I have 6 wired. TV is affected too.
- when it happens, does it say "connected, no internet" or what actually happens when you're having issues. When it happens, I lose visibility to the Netgear device. I notice there are 3 orange or red lights on far left of Netegar router. Sometimes it'll come back after 5 minutes, other times I have to unplug the router for a reboot.
Thanks
- plemansSep 13, 2022Guru - Experienced User
- MunchobaSep 13, 2022Tutor
Thank you. I had bridged it and added the Nighthawk as one of mu audio devices (a dac) was losinng connectivity with the Helix and the manufacturer suggested I do this.
I will un-bridge it and monitor.
Thanks again.
