Munchoba's avatar
Sep 13, 2022
Sporadic loss of internet connection with R7000P
Hi,   For a few months now, my router loses it's lan and wifi connection. I'm not sure where to start troubleshooting. Firmware is up to date. Any ideas? thanks
  • plemans's avatar
    Sep 13, 2022
    Try putting your helix in router mode and the netgear in access point mode.
    to often I see "bridge" mode not function properly.
    Just make sure if you leave wifi enabled on the helix to have them on different channels to prevent interference.
