czarekkb's avatar
Dec 20, 2021
SSID configuration on RAX200
My router model is: Netgear Nighthawk AX12 RAX200. Its Smart Connect feature permits one single SSID to be assigned to all three radios: 2.4GHz, 5GHz-1, 5GHz-2. Instead of using this option, I would ...
  • czarekkb's avatar
    czarekkb
    Dec 21, 2021
    Thank you again for advising.
    Just to share one observation… When I changed the config to use a unique SSID for 5GHz-2 radio, the router traffic stats immediately started to show some traffic on 5GHz-2 radio – without any devices even connected to it yet. It seemed as if as soon as the 5GHz-2 radio started to use its own SSID, it became visibly “active” in router stats view.
    Upon reflection, I will use the setup, where each radio has its own unique SSID. It will allow me to put computers on 5GHz-2 radio and do streaming on 5GHz-1 radio – thus separating “work” traffic (frequent backups over WiFi) from “play” traffic.
    Thank you so very much for all your time and sharing your expertise. MOST tremendously appreciated. Happy Holidays!
