czarekkb
Dec 20, 2021Tutor
SSID configuration on RAX200
My router model is: Netgear Nighthawk AX12 RAX200. Its Smart Connect feature permits one single SSID to be assigned to all three radios: 2.4GHz, 5GHz-1, 5GHz-2. Instead of using this option, I would ...
- Dec 21, 2021
Thank you again for advising.
Just to share one observation… When I changed the config to use a unique SSID for 5GHz-2 radio, the router traffic stats immediately started to show some traffic on 5GHz-2 radio – without any devices even connected to it yet. It seemed as if as soon as the 5GHz-2 radio started to use its own SSID, it became visibly “active” in router stats view.
Upon reflection, I will use the setup, where each radio has its own unique SSID. It will allow me to put computers on 5GHz-2 radio and do streaming on 5GHz-1 radio – thus separating “work” traffic (frequent backups over WiFi) from “play” traffic.
Thank you so very much for all your time and sharing your expertise. MOST tremendously appreciated. Happy Holidays!
Dec 21, 2021Guru - Experienced User
There maybe some balancing, however again, it's up to devices to pick and choose what signal they connect too...I presume there router helps on some level. To how much, no idea.
Something to test out. If you name the SSIDs differently then you can help force some devices to specific radios.
czarekkb
Dec 21, 2021Tutor
- FURRYe38Dec 21, 2021Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Merry Christmas. 📡
