sparky6789111
Feb 22, 2022Guide
SSID name change problem
Hi i need some help my router will not let me change the SSID name when i try all i get is what is in the image below thanks for help
Feb 22, 2022Guru - Experienced User
You've got your channel set on a dfs channel.
when you change the ssid, make sure to have the 5ghz channel set on a non-dfs channel.
sparky6789111
Feb 22, 2022Guide
It will not let me do that as you can see from image if i am in the right part
- plemansFeb 22, 2022Guru - Experienced User
what router do you have?
You didn't include much info in that picture.
depending on the router, you might need to change you "up to...." speed so you can use the standard 80hz wide channels.
- sparky6789111Feb 22, 2022Guide
sorry i have the NightHawk X6 R8000
i dont know much still learning
