Stupor08nova
Sep 15, 2022Aspirant
SSID not detected and cant connect manualy
I have a Nighthawk X6S R8000P AC4000. Internet work when connected via LAN Wifi 2.4ghz and 5ghz are enabled and are lit (LED's) on the router, however, I cannot see the SSID using PC or mobile (...
microchip8
Sep 15, 2022Master
Make sure to set SSID Broadcast to On. Otherwise your SSIDs will be hidden
It should we somewhere in Advanced -> Wireless Settings
- michaelkenwardSep 15, 2022Guru - Experienced User
It should we somewhere in Advanced -> Wireless SettingsAnd check that the wifi switch isn't off. That may sound silly, but it has happened. (Cats and infants are the usual suspects.) And the physical switch can override the GUI settings.
- Stupor08novaSep 29, 2022Aspirant
Thanks for your response. Yes, both the SSID is set to broadcast and the Switch is on. This is also confirmed by the LED on the device being lit and showing 2.4ghz and 5ghz channels are working.
There is also an error message when trying to change to any channel "This DFS channel is not allowed to use because the radar was detected before. You can change to another channel or wait"
As this is the only thing I can see that is left to try and due to the error message, I think it must be the cause of the issue.
another screenshot of settings
