Net-working
Mar 11, 2024Guide
Stable R7000 Firmware
Hi guys What the most stable firmware version for this router? I haven't updated it for ages because at the time all the new firmwares were terrible and had loads of problems.
Mar 11, 2024Guru - Experienced User
Give the current version a try:
If not, review this:
Net-working
Mar 11, 2024Guide
Thanks for the reply.
The second link you posted from 2019 is an example on why I haven't updated in a while and why I made this post.
The current firmwares are not always the best.
If no one is having problems with the latest one then I'll give it a try 👍
