Malachite
Nov 13, 2022Aspirant
Stale DNS issues on Nighthawk router connecting to Windows 10 PC's
TLDR: I think that the Netgear firmware is causing Stale DNS entries in Nighthawk routers attached to Windows 10 PC's. Greetings all, I wanted to post my experiences here in case it provides any v...
- Nov 14, 2022
The beta only fixes IP address reservation issue and a NTP configuration issue. DNS problems are still present in current 8000 FW. I can confirm that if you enable IPv6 (Auto) on the router, this resolves the DNS issues. Same goes for the 8500 FW.
We have make NG aware of the DNS issues and trying to keep pushing it.
Nov 14, 2022Guru - Experienced User
Malachite
Nov 14, 2022Aspirant
Ah, thanks for the info. I guess I may just have to keep riding the DD-WRT wave then. I only have 50M down so I likely won't hit the speed wall mentioned. In fact, with the DNS issues resolved, things seem to be running faster. My 50M connection even gave me a 70M download from speedtest LOL. Probably a fluke I know.
I made the mistake of telling the truth when I registered it just now and the support page gave me the 'F off and die message' that I can Either buy a new one or buy a support contract. Considering I have been fighting the DNS issue for the entire year I have had this router I must admit that my lifelong fanboy status took a hit and I seriously considered throwing these these two routers in a tech shredder. (Been buying their gear since the Nortel/Bay Networks years) If nothing else I think it is time for me to start researching other brands. Which is a shame because until this issue, I have never had any major problems and I love their hardware.
I guess I'll also try the IPv6 option after I let this marinate for a couple weeks to see how stable DD-WRT is. That way I can verify how it compares to having IPv6 enabled.
- FURRYe38Nov 14, 2022Guru - Experienced User
The Ipv6 configuration is only for Ng stock FW.
- MalachiteNov 14, 2022Aspirant
Yes. I meant I am going to keep DD-WRT for a few weeks to ensure that the system remains stable. If it does then I will try the factory FW with IPv6 to see if it remains as stable. That way I can ensure that the actual underlying hardware is good and solid and compare how the two different firmwares seem to be speed wise.
