jory12
Jun 02, 2022Aspirant
Starlink compatibility with a mesh and router
So I have the round Starlink dish. I replaced the router with a Netgear one so that I could link to a mesh (AC1900 WiFi Mesh Extender Nighthawk® Dual-band WiFi Mesh Extender), but I just cannot get m...
- Aug 26, 2022Thanks everyone! I just had to buy a newer router for my garage and turn that into an access point. Easy peasy.
Jun 02, 2022Guru - Experienced User
What NG router are you using?
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
1. Configure the modem for transparent bridge or modem only mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ/ExposedHost or IP Pass-Through for the IP address the NG router gets from the modem. https://kb.netgear.com/25891/DMZ-on-NETGEAR-routers
https://kb.netgear.com/24086/How-do-I-set-up-a-default-DMZ-server-on-my-Nighthawk-router
3. Or disable all wifi radios on the modem and connect the NG router to the modem, LAN to LAN configure AP mode on the NG router.
jory12
Thanks. I don’t really understand that. Others say they plug and go. I must have the wrong setup. I think I need a mesh only system - multiple meshes? No router? The nighthawk app can not identify the mesh. It’s the R7450 nighthawk router.
- FURRYe38Jun 02, 2022Guru - Experienced User
You'll need to ask the ISP if a Netgear router and be used in place of there router.
