jory12
Jun 02, 2022Aspirant
Starlink compatibility with a mesh and router
So I have the round Starlink dish. I replaced the router with a Netgear one so that I could link to a mesh (AC1900 WiFi Mesh Extender Nighthawk® Dual-band WiFi Mesh Extender), but I just cannot get m...
- Aug 26, 2022Thanks everyone! I just had to buy a newer router for my garage and turn that into an access point. Easy peasy.
Jun 03, 2022Guru - Experienced User
1. You said you replaced the starlink router with a netgear one but not a model. what actual router are you using? (model)
2. what extender are you using? (hint ac1900 is a speed, not a model. look at its label)
3. Not sure if starlink supports a direct connection to a netgear router without their starlink setup. Did you check with them?
