Rickbloke
May 19, 2021Aspirant
static route pointing to R6250 from a R7000
Hello I have my main router which is a R7000 on 192.168.1/24 network and I have a R6250 on 10.1.1.0/24 network, I am trying to set up static routes to get to the 10.1.1.0/24 mainly a webserver on...
schumaku
May 19, 2021Guru - Experienced User
How is everything connected, especially the WAN/Internet ports of the two routers?
Be aware these are always NAT routers, no full subnet routing for the obvious reasons...so port forwarding might be required instead of routing.
Rickbloke
Hi
The WAN port of the R6250 is connected to one of the LAN ports of the R7000 via a basic switch, there is a NAT Filtering on the WAN setup page but I have tried different things on and off on this page and still not helped.
