Jmv32's avatar
Jmv32
Follower
Nov 23, 2024
Steaming tv
Sorry for the dumb question 🙂
I'm unable to connect to my streaming on my tv. I was told that I needed to download the nighthawk app and select the one that I want to give access to. BUT I don't know how to go about downloading this.
1 Reply
  • FURRYe38's avatar
    Devices don't need the Nighthawk app to connect devices. You have to go thru the devices networking to get it connected.
    Unless you have Smart parental controls enabled, should be able to get any device connected using the WiFi SSID name and password set on the router. Check the the devices Mfr support and information on how to get there product connected.
    What NG router model do you have ?
