djp787
Dec 07, 2020Follower
Step by step instructions to add Expressvpn to my router
I really need step by step instructions on how to install Expressvpn on my R6700v3. I've talked to Expressvpn 3 times with no luck. They said I have it installed on my PC but not t...
Dec 07, 2020Guru - Experienced User
Expressvpn is a 3rd party firmware for the router. Its not stock firmware and you won't find help for it on the official forums. You can try expressvpn forum.
there is a guide on expressvpn.
https://www.expressvpn.com/support/vpn-setup/app-for-routers-netgear/
michaelkenward
Dec 08, 2020Guru - Experienced User
That question comes up regularly.
In addition to the advice from plemans you could try a search of this place.
Search - NETGEAR Communities – Expressvpn
