Retired_Member
Jun 15, 2019Steps to Connect Nighthawk X6 R800 Router to DM200 Modem
Hi there, As the title says, I'm hoping to use the DM200 Modem with a Nighthawk X6 router on my Zen Internet (UK) VDSL connection. Apologies if I sound dumb, but I've always made-do with the ...
- Retired_MemberJun 16, 2019
antinode wrote:> [...] Eventually figured out which setting hidden away in the Advanced
> menu needed changing to get it online.Imagine how grateful some future reader with a similar problem will
be when she finds that precise, detailed description of how you solved
_your_ problem.Probably about as grateful as I was that the help offered to me amounted to read the manual.
But hey, you're right - it's not the fault of some poor random individual who just wants to get rid of their Fritz!Box. So with that in mind, here we go...
Step 1) Plug in and setup modem. DM200 includes preconfigured setup for Zen Internet, although if you're worried about DLM being its usual jerky self, just bypass the config and set it up manually. This negates needing to reboot it. All the details needed to configure the modem are available in the Zen Customer Portal - you need to view the Detailed views under 'Your Services'. Your Username and Password are available there, and will also be in your welcome email.
Step 1a) When it asks for VLAN ID, put '101'.
Step 2) I cannot remember the name of the menu, but it's something like 'State' - hunt around, you can't break anything. Check 'Passthrough VLAN' before putting modem in Modem Only mode.
Step 2a) Forget ever seeing the Modem config screen ever again, since the IP address doesn't seem to work.
Step 3) Plug in Nighthawk. Connect it up using the fancy shielded ethernet cable provided. Ignore Netgear Genie, because it's useless and set up the connection manually by going into Internet and entering all your login details and the static IP Zen gives you. You don't need to set DNS, unless you want to use CloudFlare, Google or what have you.
Step 4) Head over to Advanced, click Advanced Setup and then VLAN/IPTV. Edit VLAN value to '101'. Make sure you enable VLAN again after editing the value because for some reason, it changes the value to disabled again once you've edited it. Not sure why such a vital setting to get online would be listed under Advanced rather than basic, but here we are.
You should then have Internet access. Huzzah!
Added QoL steps:
Step 5) Do the Firmware update before you do anything else, otherwise the router will start rebooting every time you try and download a file. I have no idea why it was doing that, but the FW update seems to have fixed this bout of tomfoolery.
Step 6) Assign wired devices a reserved IP address by going into Advanced -> Setup (NOT Setup Wizard) -> LAN and configuring it there. Failure to do so will mean anytime the router does reboot, the IP address will change and if you're running a media server or something like that, you're going to have a bad time if the IP keeps changing.
I think that about covers it all for Zen Internet at least. Can't say whether this would work with all over UK ISPs.
michaelkenward
Jun 16, 2019Guru - Experienced User
Retired_Member
Jun 16, 2019It wasn't as straightforward as I'd liked but I have it working.
DM200 setup easily enough. Getting the Nighthawk to work was a pain. Eventually figured out which setting hidden away in the Advanced menu needed changing to get it online.
- antinodeJun 16, 2019Guru
_your_ problem.- Retired_MemberJun 16, 2019
Added QoL steps:
- IrvSpJun 16, 2019Master
I'm sorry I offended you with my suggestion to look at the DM200 manaul. You DO know you put this into the Nighthawk Router Forum, not the CABLE MODEM FORUM where it should have probably been. You might have gotten better instructions there.
Never mentioned VLAN at all, not sure "Added QoL steps:" means, 'Quality of Life" or "OoS". QoS can slow you down, especially if the ISP speed is over 200Mbps.
As for Reserved Addresses, not always needed, depends on how you address the device, by its IP Address (then you need it) or the SHARE name, then you don't. This does depend on the DLNA client though.
Bottom line, you might have been better off in the proper forum. Secondly, a more detailed post of what your problem was, what you needed to do, and what you might have tried would have gotten you a better response probably.
Like you said, 'read the manual' was the way to go, and if you had done that and stated so it sure would have helped. It does seem though that did help you figure it out. No need to disparage.
