DK-Eric
May 08, 2022Tutor
Still problems with Intermittent Nighthawk X6S R8000P
This problem was raised back in September 2021. Recently, I updated my R8000P Firmware to Version 1.4.3.88 Afterwards, I get the attached message all too often from many different sites. I also h...
May 08, 2022Guru - Experienced User
1. I've heard there's a firmware in the works but its not ready for general release.
2. some of the issues were fixed with simply enabling ipv6 and rebooting the router. Have you tried that?
3. the one we usually refer people to if ipv6 doesn't fix the issue is the 1.4.1.68 version. you can try installing that and doing a factory reset/reinstall.
