oldergeek
Apr 23, 2022Aspirant
stop working
my wifi router stop working the internet light is on but no internet. I have a nighthawk R7000is it broken do need a another.
what modem/gateway is it connected to ?
What firmware is on the router?
What actual error are you getting? Connected, no internet? Is the wifi broadcasting at all?
Do wired devices work?
What have you tried doing to fix it? reboot the modem/router? Factory reset the router and reinstall it?
What changed?
- oldergeekAspirant
netgear modem
fimware can`t remember the number
no internet
wired work
yes have rebooted
changed nothing
- wcalifasProdigy
Do another hard reset by pressing the reset pinhole with a paper clip. Before rebooting the router, restart your modem and wait til it syncs up with the internet. When the internet lights up then connect the router to the modem and see if that fixes it.
