IAAPG
Aug 08, 2021Follower
Stopping DDOS attacks
, Hi all, I've noticed that every ten minutes I'm getting a DDOS attack from fe80:0000:0000:0000:3e41:0eff:fe1f:c819. I can't trace it and I'm unsure how to blacklist/block ip addresses. I do no...
DarrenM
Aug 19, 2021Sr. NETGEAR Moderator
I would suggest using the DOS protection on the router.
https://kb.netgear.com/19957/What-does-Disable-Port-Scan-and-DoS-Protection-do
DarrenM
