router_help's avatar
router_help
strange Foscam camera issues with R6300 and R6900
TL;DR: foscam cameras work great on other routers outside the wifi network, but do not work reliably with two Netgear routers now. On the latest R6900 router, cameras work well on Cricket (AT&T) netw...
  • TheEther's avatar
    TheEther
    Jun 11, 2016
    Turning off Port Scan and DoS Protection is not a big deal.  It just disables some extra heuristics that drop traffic more aggressively.  The main protection comes from NAT and that, by necessity, remains enabled, so your network should still be safe.
