Bobforeman
Apr 26, 2022Initiate
strange message
when I open a web page it pauses briefly and says "cant reach page" check your network connection, but then it opens up? I have upgraded my firmware. I have the Netgear Nighthawk X6 AC3200 Model R800...
Apr 26, 2022Guru - Experienced User
1. what modem do you have?
2. what firmware (not the latest) is installed?
3. have you enabled IPv6? If not, enable it
- BobforemanApr 27, 2022Initiate
Modem is a Fiber Optic Intertex provided by Metronet
Firmware is V1.0.4.84
IPV6 is enabled
- plemansApr 27, 2022Guru - Experienced User
Try a factory reset.
If that doesn't help, try rolling back the firmware a version. we seen a lot of dns issues on that version
