Bobforeman
Apr 26, 2022Initiate
strange message
when I open a web page it pauses briefly and says "cant reach page" check your network connection, but then it opens up? I have upgraded my firmware. I have the Netgear Nighthawk X6 AC3200 Model R800...
Apr 26, 2022Guru - Experienced User
1. what modem do you have?
2. what firmware (not the latest) is installed?
3. have you enabled IPv6? If not, enable it
Bobforeman
Apr 27, 2022Initiate
Modem is a Fiber Optic Intertex provided by Metronet
Firmware is V1.0.4.84
IPV6 is enabled
- plemansApr 27, 2022Guru - Experienced User
Try a factory reset.
If that doesn't help, try rolling back the firmware a version. we seen a lot of dns issues on that version
