ghumor's avatar
ghumor
Follower
Nov 11, 2021
Strange performance issues RG6700-100NAS v3
Firmware up to date (V1.0.4.120_10.0.91) per upgrade attempt.
This problem started about a month ago.
Symptoms:
1) Websites often fail to load, must be refreshed (F5) several times.
2) Forticlient VPN fails to extablish connection without several "connect" attempts.
3) "Wifi call"s on 2 smartphones fail to have inbound sound.
  • plemans's avatar
    There's been multiple reports across multiple product lines with this issue.
    Some have been fixed by enabling ipv6.
    Others have been able to change the dns provider.
    And yet others have had to downgrade the firmware a version (or 2) to get it working properly again.
  • I had the same issue with the latest firmware, multiple reloads, or a website loading without all features.
    Try unselecting any MultiMedia settings, that worked for me.
    TD
