Tech073's avatar
Tech073
Follower
Mar 01, 2022
Strong router
I have a horse that is going to foul in the next few weeks and am setting up a camera to livestream her stall to the house.
My present router won't do it. I need one that will go the distance between house and barn, which is 200+ feet.
The present router will work to near the but not into the interior.
What netgear router is the best one? Price is not the number one issue, signal strength is.
  • plemans's avatar
    It isn't going to be a "stronger" router that you need. Broadcast strength has been set from the fcc and most routers have already maxxed it out for years.
    What you'd need is either a point to point system to reach the barn, a buried underground ethernet wire, or potentially a triband mesh system might work. But thats a *might* as the signal might not be good enough to penetrate the barn walls.
    • FURRYe38's avatar
      You might reveiw this:
      https://www.netgear.com/business/wifi/wireless-bridges/wbc502b2/
