Guac
Mar 12, 2024Aspirant
sudden 403 on a single website R7000
10 yr old Nighthawk R700; has worked like a champ. Suddenly delivers 403 firbidden trying to access ONE website (a broker) (Tradestation.com) for ALL devices in house. Usual tricks don't work (r...
- Mar 19, 2024
Thanks all for the suggestions. For the sake of closure:
I Replaced my 10-yr old workhorse R7000 w/a new AX4200 (RAX43) which resulted in a new IP being assigned. Problem solved.
Mar 13, 2024Guru - Experienced User
Guac wrote:
Is any Armor or parental controls enabled on the router?
No
Any changes made to the router as of late?
No
Version1.0.9.88_10.2.88
Ya, your behind in FW. Maybe time to update.
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Motorola MB8610
Try different DNS on the router from the auto detected ISP DNS by the router?
Huh? I have "Get Automatically from ISP" checked when I log into the router. I have not tried "Use these DNS servers" option (out of fear of the unknown)
Try using Google or Cloudfare DNS custom DNS here to see.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
yes
Turn off and unplug modem.
Turn on the router and wait 2 minutes for it to connect.Turn on computers and rest of network.
Done many times; problem still there
Maybe a factory reset and setup from scratch would be in order.
Guac
Mar 19, 2024Aspirant
- FURRYe38Mar 19, 2024Guru - Experienced User
Possible that may have been the issue. Just needed a new WAN IP address.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-route
Enjoy. 📡
