SGoulding
Nov 01, 2021Tutor
Sudden drop in throughput
Late last week, noticed internet slow. Troubleshooting eliminated everything except the Router. NBN connection is AussieBBS 250Gb download speed. For the last 3 days best performance has been 30G...
Nov 01, 2021Guru - Experienced User
A couple things.
1. I think you mean Mbps. not Gig
2. what firmware is on the r8000?
3. what modem/gateway/ont is the R8000 connected to?
4. did you do anything that might have changed it? (moving stuff around, etc)
- SGouldingNov 02, 2021Tutor
Yep - my bad, Mb not Gb download
Firmware = V1.0.4.76_10.1.82 (Latest version) Been on router & working fine since released a while ago.
Nothing chas changed, no reloactions, no different equipment, nothing changed.
Router connected to NBN equipment (Arris CM8200)
- plemansNov 02, 2021Guru - Experienced User
try factory resetting it.
Push and hold reset for 7-15 seconds while powered on.
Then during the install, make sure to leave qos, access control, traffic monitoring, and parental controls all disabled.
- SGouldingNov 06, 2021Tutor
OK Please read carefully before replying to save us both time :-)
I have tried everything listen in Netgear support including
All 3 methods of reset
Tftp load of previous firmware.
None of the resets changed anything.
Tftp failed (tried > 5 times, including using different Tftp clients)
When trying to connect to an isolated router (only connected to PC) get error message
"routerlogin.net not working - failed to send any data"Process for trying to connect includes entering default IP address 192.168.1.1 into browser window
watching the following appear
www.routerlogin.net/start.html
www.routerlogin.net/genie_index.html
message "www.routerlogin.net did not send any data"
When ever I managed to get a login prompt (i.e. trying to acces via WiFi) I get a incorrect password response to entering "password"
Downloaded Nighthawk app to mobile phone...
Phone app cannot find router
OK Ideas ????
