SGoulding
Nov 01, 2021Tutor
Sudden drop in throughput
Late last week, noticed internet slow. Troubleshooting eliminated everything except the Router. NBN connection is AussieBBS 250Gb download speed. For the last 3 days best performance has been 30G...
Nov 07, 2021Guru - Experienced User
What error is tftp giving you?
Have you tried nmrpflash?
SGoulding
Nov 07, 2021Tutor
tftp errors - all to do with unsuccessful upload and couldn't connect, tried so many times, it got bored giving me the same error messages :-)
Have you tried nmrpflash? Yes didn't work
- plemansNov 07, 2021Guru - Experienced User
tftp/nmrp are sensitive to timings/spelling/etc.
As well as making sure your router is responding at the right times.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done. Again, its sensitive to timings.
https://www.youtube.com/watch?v=R9DLrLQrpaw
Have you tried a different power supply with the router? Maybe your power supply is sketchy? - SGouldingNov 07, 2021Tutor
Hi
Can I ask did you obothere to read the previous threads ?
'Cause it seems like the thing to try before suggesting some-one with over 20 years using TFTP they look at some traing videos on how to use it. At least ask the person if they have any experience 1st, it saves time and stops you looking like a patronising...
Also you might actually try testing the links you send, yours gave the following error
Forbidden
You don't have permission to access this resource.
Additionally, a 403 Forbidden error was encountered while trying to use an ErrorDocument to handle the request...
As mentioned previously I have tried all the obvious, and I did make the assumption that included eliminating all the basic things like
Cables,
PC's
Power supplies,
locations (for WiFi)
without having to enumerate every single one.
Still looking for some realy quality assistance...
- plemansNov 08, 2021Guru - Experienced User
SGoulding wrote:
Hi
glad to know you have over 20 years of tftp. You put your whole bio when you posted on here and I must have just missed it.
I'll be happy to sign off to your expertise then.
Good luck.
