Primatet
Jun 17, 2016Aspirant
Sudden network issues with a NASNetwork, Troubleshooting
I have a Synology NAS hooked up t my Netgear router. It has worked flawlessly up to now. I can access the nas via http://192.168.1.8:5000/index.cgi I can access any of the shares. The IP adress fo...
- Jul 16, 2016
Turns out it was the NAS was the source of error. Did a fabric reset that solved everything
Primatet
Jun 20, 2016Aspirant
Cant ping nas from any clients. Have rebooted and fabric reset router. Used saved setup. Only error message is that share is not available, or nas not avsilable. Only available via beowser
VE6CGX
Jun 20, 2016Master
Have you set up the home group? How about access right? Every one is allowed to access? Funny thing is it used to work
you say.. Double check access right issue with or without password.
