Primatet
Jun 17, 2016Aspirant
Sudden network issues with a NASNetwork, Troubleshooting
I have a Synology NAS hooked up t my Netgear router. It has worked flawlessly up to now. I can access the nas via http://192.168.1.8:5000/index.cgi I can access any of the shares. The IP adress fo...
- Jul 16, 2016
Turns out it was the NAS was the source of error. Did a fabric reset that solved everything
Retired_Member
Jun 22, 2016
Primatet wrote:I have 7-8 devices, most with windows 10.
Windows 10 $uck$ I went round and round with same B$ almost 2 years ago as a beta tester for Win 10. It's a security setting in WIN 10. I dumped it and went back to Win 7.
Primatet
Jun 25, 2016Aspirant
Thats really not an answer. As said in initial post it has worked flawless up until a point.
I have several W7 clients aswell, same problem there, so no, its not a W10 problem.
